Not sure how others feel but I made up hydraulic hoses and adapters to hook up to a good tractor with hydraulic remotes. You need to remove rocker arms so all valves are shut all the time. (This good time to double check if valves are working.) Take out all spark plugs. Plumb the two mated cylinders (1&4 or 2&3 on Super C) together on one side of hyrdarulic remote and other pair on other side. This allows you to work engine back and forth. Also you will get lubrication from hydraulic oil. You get an even push on top of your piston and the force is greatly increased due to the surface are of the piston. Once it is free, crank the engine several times with plugs out to allow oil to blow out. Used this method on at least 10 engines. Little messey, but it works for me.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
