Posted by EZ on May 08, 2009 at 10:11:37 from (206.47.210.58):
Guys, I finally got a nice oiler gear for the 130 and started putting the trans back together. I tightened up the retainer bolt to pull the shaft into the 213T bearing. It is as tight as it will go and I still have some play in the oiler gear and the spacer. Should this spacer be snug? There are 5 shims on the retainer end for the back lash that will be staying place. I probably have about 1/32" of play on the oiler gear.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
