Re: Super C engine froze
Posted by rustred on May 08, 2009 at 12:18:52 from (72.172.100.113):
In Reply to: Super C engine froze posted by Tom52 on May 08, 2009 at 03:05:36:
stuck valves DO NOT lock up an engine like stuck pistons. you are still able to turn it and will feel the hard spot when cranking it, and if you continue to turn it over it will bend the push rods or break the rocker if the valve is in the closed position. i have seen most engines seise from being shedded due to the condensation than ones that just sat out side.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
