Posted by Owen Aaland on May 08, 2009 at 22:14:56 from (65.165.246.54):
In Reply to: changing an H axle posted by Brad in WI on May 08, 2009 at 20:51:09:
The four bolts on the outer cap are what hold the axle in place. The easiest is to leave the wheel on to start with. Take out the four outer bolts With the tractor blocked up so you can turn the wheel, use a wrench through the PTO opening. Turn the wheel to loosen the bull gear retaining bolt. Once the bolt has been loosened, use a spacer between the two bull gear bolts and continue the turn the wheel to unscrew the bolt. As the bolt unscrews it will force the axle out of the bull gear and inner bearing. It will also push the outer bearing out along with the axle. When you run out of threads, if the axle is not loose enough to pull out, you can remove the heavy washer and screw it back in the axle, use a longer spacer or a longer bolt and repeat the procedure.
Going back together, block the bull gear up so that it is centered on the inner bearing. Leave the outer off the axle. Run the axle through the inner bearing. you can move the outer end around a little to help line up the bull gear. Once the bull gear is started on the axle you can use a longer bolt in the end of the axle to bull it together enough to get the original bolt started.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
