I had given that a thought but the entire hitch is a wreck....I fab'ed a new cylinder bracket but the rockshaft has been welded...all holes need bushed with pins fixed.....the tractor belly casting where the hitch mounts has one threaded holes broken out...I have a bolt in it but it doesnt hold much and hate on relying on the two remaining bolts for heavy pulling...
The newer tractors had a much better mounting system from what Ive looked at....
I will probably "fix" the arms for the rest of the season to keep the slop to a minimum....dont need the plow till fall...
I may look for a trailer plow...something like a 3x16 or 4x14 .....or if I get time I could build my own 3 pt and use a semi mount....I use a 3x14 fasthitch plow now.....will sell it if I get something else..
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
