Re: Super A rear axle mystery
Posted by Terry Hartzell on May 09, 2009 at 06:59:39 from (66.59.104.72):
In Reply to: Super A rear axle mystery posted by Terry Hartzell on May 09, 2009 at 04:54:47:
EZ, I do have a parts manuel, it calls for one long spacer on the outer side of the bull gear, which I have. The manuel calls for a spacer between the bull gear and the bearing on the inner side, which I have. On the inner side of the inner bearing, I have one spacer, then a washer and then the bolt. All according to the parts manuel. I don't know if the spacers that I have are the right thickness since the book doesn't say how thick they are supposed to be. I have had the axle out, replaced the oil seal. I can't see why I have the in and out play unless my spacers are incorrect thickness. I am baffled.
Terry
