Re: 450 hose routing
Posted by bkpigs on May 09, 2009 at 08:29:27 from (12.50.51.2):
In Reply to: 450 hose routing posted by colekicker on May 08, 2009 at 21:24:44:
My 300 has steel lines that run from the hydra-touch to the rear. I would immagine that your 450 would be the same setup. You can go on ebay to try to find some (once and a while you can find some good treasures on there) or go to www.caseih.com and look under the parts parts search and it will give you a blown up view of the hydraulic system.
