656 no remote hyds
Posted by han on May 10, 2009 at 05:53:35 from (76.4.194.122):
tractor has good pressure at an idle but looses it at 1/4 throttle.changed filtr added extra oil, only way remotes work over this rpm is to hold steeringone way or the other.anyone ever run into this?thanks allen psi at idle is 1800 then goes to 4-500
