Re: Installing a wide frontend on a Farmall Super M
Posted by Allan In NE on May 10, 2009 at 06:06:26 from (148.78.100.118):
In Reply to: Installing a wide frontend on a Farmall Super M posted by farmerhr on May 09, 2009 at 20:21:26:
The easiest way is to just stick a plug in that radiator and drain the system using the block drain, which is easily accessible and right out in plain view.
Allan
