Re: No spark @ #1 plug - IH140 - Update
Posted by NawlensGator on May 10, 2009 at 13:35:39 from (68.155.75.60):
In Reply to: Re: No spark @ #1 plug - IH140 - Update posted by Dellbertt on May 10, 2009 at 10:59:10:
The missfiring of the #1 plug is no longer happening according to the timing light. All 4 give a steady strobe.
Just finished a compression check. 150 - 155 psi on 2, 3, & 4. No. 1 was 125. Went to recheck #1 and realized the fitting wouldn't bottom out (i.e. it wouldn't seal). Then I realized the plug wouldn't go in but a couple threads either before stopping. So it looks like threads have been crossed somewhere along the line. The electrode gap end of the plug stops a long way from the cylinder ID. Could this could be the problem? I've not paid attention to this in the past. Maybe there's different problem with #1. 125 sounds pretty good but it's still 25 below the rest. Or maybe it's just a sealing issue.
Can I run a reamer / tap in to clean up the threads without yanking the head? Looks to be 11/16ths thread. I'll check the neighbor and buy one tomorrow if he doesn't have one. I'll report back. If this doesn't fix it I'll run the other checks suggested. Thanks for all the good thoughts and suggestions. I'll report back.
