Re: 5088 won't start - any ideas?
Posted by El Toro on May 10, 2009 at 15:16:16 from (64.12.116.73):
In Reply to: 5088 won't start - any ideas? posted by Westernspecial on May 10, 2009 at 10:25:50:
Check all your battery cables to see if they're cracked. It they are replace them. Clean all connections until shiny and that includes the area where your batteries are grounded. Once you have it running check your charging voltage across the batteries with the engine at 1/2 throttle or better with a volt meter. On a 12 volt system you should have 14.5 volts. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
