Re: Dead H
Posted by CNKS on May 10, 2009 at 17:17:24 from (216.144.104.128):
In Reply to: Dead H posted by Cory B on May 10, 2009 at 17:08:13:
Jack up one rear wheel, put it in gear and try to turn the wheel. If you can't see the fan turn, loosen the starter and wiggle it a little. The drive gear got locked to the ring gear. Common intermittent problem if the starter gear and/or ring gear are worn. Your engine simply stopped on the "bad" place.
