Re: Distributor for Super A
Posted by james Ashcraft on May 10, 2009 at 18:44:56 from (70.244.167.249):
In Reply to: Distributor for Super A posted by james Ashcraft on May 09, 2009 at 15:53:32:
Update on distributor - removed from tractor today - the shear pin was broke but both gears were good. Removed point plate and the long screw had did a little damage to the cover over the automatic advance. Got all that fixed and put a pin in the shaft and gear - reinstalled shaft with bottom gear and discovered shaft is bent. Now have to find another distributor.
J. Ashcraft
