Re: SA Transmission and Final Drive lube
Posted by mattofvinings on May 10, 2009 at 20:29:43 from (67.142.161.31):
In Reply to: SA Transmission and Final Drive lube posted by mattofvinings on May 10, 2009 at 12:11:12:
Thanks to all for the info so far. The SA is the best grass cutter I've yet owned and I want to make sure it stays that way! My engine needs a rebuild as I'm smoking out the crankcase breather under load but I'm going to try to make it thru this year before I undertake that....(then hopefully inside a temp-controlled and dry building :) )
