Re: ONAN Twin cylinder engine ignition coil
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by ltf in nc on April 10, 2000 at 17:42:55 from (206.228.214.72):
In Reply to: ONAN Twin cylinder engine ignition coil posted by S. Bogacz on April 09, 2000 at 02:20:16:
Bo, First let me tell you that I have never done what I am about to suggest. This aside, I have seen the set up and as I understand the circuit, both spark plugs are fired at the same time. Only one plug is on compression and fires and nothing occurs at the other plug other than it firing and on the next cycle it just repeats except that it fires the alternate plug. The reason for the two high tension outlets is just for convenience to accommodate both high tension wires. A car coil with a single high tension outlet should work if you do a little improvising. All you need to do is determine how to connect both plug wires to the one high tension outlet. If you get some spark plug wire that has a wire core instead of carbon you could make a wire arrangement that looks like the letter Y and put the base into the coil and run the top parts to each plug. You could also get a brass screw and place it in the coil outlet and put eyelets on the wires and mount them to the screw. It may be necessary to epoxy the screw into the coil outlet. Jaguar cars run two coils on their 12 cylinder engines in order to create high voltage for the 12 cylinders at high RPMs. The Onan does not turn fast enough, nor have enough cylinders, to require the voltage to be that high. Post your results so that we all may share in your repair.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
