Re: Dead H
Posted by El Toro on May 11, 2009 at 03:55:15 from (205.188.116.73):
In Reply to: Dead H posted by Cory B on May 10, 2009 at 17:08:13:
Check the voltage on your battery using a volt meter should be at 6 volts. It may be a dead battery if your generator isn't charging it. Check your battery cells with a hydrometer and see what your readings are. Should be around 1.260 and if one cell is 1.100 you have a dead cell and you need to replace the battery. As been mentioned clean all your battery connections.
You should have 00 battery cables on a 6 volt system. If you can get it started check the charging voltage across the battery terminals. Should be 7.2 volts with the engine at 1/2 throttle or better. Hal
