Re: 10-20 steering
Posted by spiffy1 on May 11, 2009 at 07:28:19 from (70.41.137.72):
In Reply to: 10-20 steering posted by Bob on May 10, 2009 at 10:46:04:
I have the 15-30 set-up stuck in my head right now [which didn't have the offset to tighten the gears like a 10-20] but if the worm is less than half the problem - you may be able to treat it like a 15-30:
remove the linkage arm, remove the shaft assembly and turn the shaft 180 before reinstalling the linkage arm. If that was already done once [and now with the 15-30 brain block in my head, I may be wayyyy off], it still likely leaves you with 2 more spots as the wear happens more in a 90 (actually probably more like 30!) degree area, but bolt reliefs were not provided in the perpendicular directions so if you grind in bolt reliefs and you may be good to go twice more.
