Re: Dead H
Posted by Larry in WNY on May 11, 2009 at 09:19:00 from (12.31.22.12):
In Reply to: Dead H posted by Cory B on May 10, 2009 at 17:08:13:
Cory,
While you're cleaning the battery terminals, unhook the ground wire first, then disconnect the lines going to the starter button to clean those ends too. I've had bad connections here preventing power from going to the starter. Sometimes it will spark which makes it easy to identify, but not good being close to the gas tank. Bad connections can cause many problems. I had to get a new push button switch for my H.
Larry
