Re: OT: Case 1030 Hydraulics
Posted by Dellbertt on May 11, 2009 at 16:34:40 from (209.172.21.134):
In Reply to: Re: OT: Case 1030 Hydraulics posted by El Toro on May 11, 2009 at 05:31:23:
third party image
third party image
Everything is in the rear housing on a Case 1030.
Comes out of the pump into a filter then back and up into the aux valve assembly then through that to the rockshaft valve.
The rear housing has always been dry but now I have a pretty good leak where the aux shaft levers go up into the aux assembly, so I guess I am going to have to yank the fuel tank and rebuild the aux valve assembly anyway.
In the photo the yellowish square on the back is the pump, then forward to filter then you see the up tube into the aux assembly.
Just wondering if the IT Manual does a good job of troubleshooing this section.
Thanks,
Dell
