Re: !951 Super A temp placement
Posted by Hugh MacKay on May 11, 2009 at 17:38:41 from (209.226.106.29):
In Reply to: !951 Super A temp placement posted by Jeff Sharp on May 11, 2009 at 17:19:44:
Jeff: The one I saw had the gauge almost directly over the timing gears. I didn't look close, but suspect it must have been attached by bolts that attach governor to engine. I don't have the answer on the probe, however my SA has a plug in the side of upper water port. That has to be where it goes.
Not sure why you folks get so gung ho about water temp gauges on Super A tractors. We worked these and worked them damn hard for 500-600 hours per year for 50 years with no temperature gauge. If you guys would just listen, a Super A talks to you. It will tell you when timing advance is correct. It will also tell you went it's hot, or not hot enough. It does this better than any engine I've ever been around.
