Re: PTO belt pulley belts - sources - repairs- lengths- h...
Posted by mattofvinings on May 11, 2009 at 21:42:44 from (67.142.161.32):
In Reply to: PTO belt pulley belts - sources - repairs- lengths- how to? posted by Dan G on May 11, 2009 at 19:24:29:
The way I get lengths is to measure the centerline distance between the two sheaves.
Then measure the diameter of each sheave.
Add the centerline distance + 1/2*pi*dia1 + 1/2*pi*d2
That will usually get pretty close, within an inch of total belt circumference in my experience...I'd guess that's close enough for a flat belt.
