Re: throttle not engaging on a farmall h
Posted by Tractor,Tractor on May 12, 2009 at 09:05:22 from (98.28.54.178):
In Reply to: throttle not engaging on a farmall h posted by larry ernst on May 12, 2009 at 08:48:30:
I suppose if you run over your pastor your throttle should stop!!!
