Re: throttle not engaging on a farmall h
Posted by John G. Hasler on May 12, 2009 at 09:25:41 from (64.91.34.95):
In Reply to: throttle not engaging on a farmall h posted by larry ernst on May 12, 2009 at 08:48:30:
Sounds like you may have a problem with the speed control linkage or the governor, but we need more information. What happens when you open the throttle plate right at the carburator?
