Re: throttle not engaging on a farmall h
Posted by rustred on May 12, 2009 at 09:35:56 from (72.172.100.113):
In Reply to: throttle not engaging on a farmall h posted by larry ernst on May 12, 2009 at 08:48:30:
pull the governor plate off and you will most likely see the spring is broken.
