Re: cub lo-boy
Posted by Jred on May 12, 2009 at 10:02:04 from (206.18.168.224):
In Reply to: cub lo-boy posted by kennedy on May 12, 2009 at 08:29:06:
it can also be the main jet in the carb, there should be a seal below it since it sits below the fuel level. if the seal is not there or its bad it can poar out the intake.
