Re: 706
Posted by pete 23 on May 12, 2009 at 10:47:28 from (173.87.8.95):
In Reply to: 706 posted by MAK on May 12, 2009 at 06:47:39:
Just push and hold pedal for a while,if they come around then, you eiether need to bleed them or your self adjusters are not working properly, if pedal does not respond while holding pedal, the orfice at the inlet fitting to the brake valve may be plugged.
