Re: Dead H Update
Posted by Owen Aaland on May 12, 2009 at 11:11:03 from (65.165.246.54):
In Reply to: Dead H Update posted by rustyfarmall on May 12, 2009 at 10:09:01:
rustyfarmall said: (quoted from post at 10:09:01 05/12/09)
Good to know the problem is solved. A new starter drive and/or a new flywheel ring gear would prevent that from happening again, but then I have an H that will do the same as yours did, but only once every two years or so. One of these days I'm gonna fix it.
Or, if you are on the cheap side, you can dress the end of the starter drive teeth to restore the original bevel.
