Re: Farmall 140 not running well
Posted by NawlensGator on May 12, 2009 at 11:36:45 from (52.129.12.52):
In Reply to: Re: Farmall 140 not running well posted by seventy468 on May 12, 2009 at 11:10:25:
So it loses power under load. Remember, if plugs are firing only half the time, you're left with half the power which could cause a stall under load. Here's one trouble shooting tip (after you check rest of ig sys), if you have a timing light, put the pick up on each plug wire and see if you get a steady strobe on each.
