Re: No. 8 plow tires
Posted by IHCPloughman on May 12, 2009 at 12:05:23 from (129.186.104.70):
In Reply to: No. 8 plow tires posted by Cedric on May 11, 2009 at 09:09:18:
rustyfarmall said: (quoted from post at 16:57:05 05/12/09)
I have a pair of 6.00X16 tractor fronts on my #8, and it does work quite well, but I can't get quite enough adjustment from the levers to make that first, opening pass be the same depth on both bottoms. A 7.50X16 tire on the land side would provide more adjustment.
I have a 7.70x15 or 8.70x 15 (don't remember) (30 yr old sow/mud tire)on the land wheel and a 6.00x16 tractor tire on the furrow wheel. My plow works fine plowing the crown. Perhaps your lift rod is the wrong length? I found a fabricated longer rod on a plow of mine. Also, there are two holes for attaching the quadrant to the furrow axle arm (one for steel, one for rubber tires).
Redblood, everyone is correct so far. Whatever fits. I like to see at least a vintage looking tire, not a modern 16" car radial.
This post was edited by IHCPloughman at 12:08:56 05/12/09.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
