Re: throttle not engaging on a farmall h
Posted by usetabesteve on May 12, 2009 at 12:06:47 from (168.166.54.11):
In Reply to: throttle not engaging on a farmall h posted by larry ernst on May 12, 2009 at 08:48:30:
I agree with Roy and Rustred. Pull that plate off the side of the governor case and look for the broken spring first.
Also, I can of quite a few pastors that might need run over with a Farmall H. A whole bunch of politicians might need run over, too.
