Re: 706
Posted by ChrisAS on May 12, 2009 at 13:52:12 from (64.5.67.116):
In Reply to: 706 posted by MAK on May 12, 2009 at 06:47:39:
Max
You said power steering is ok. First test is with engine running. Bush one peddle as far as it will go then push the other if first peddle moves more the self adjuster in that brake should be working. Then reverse the test to see if the other peddle moves more, if so that self adjuster is working. I would say they are not working and that is the problem. If that is the case the test bill not work as stated.
