Re: In-Line Fuse
Posted by TractormanNC on May 12, 2009 at 16:55:30 from (209.42.179.242):
In Reply to: In-Line Fuse posted by Johnny Lawson on May 12, 2009 at 05:10:54:
Johnny,
If you want some protection in your charging circuit, do what the OEMs do. Put a "fusible link" in the system where the small wires hook to the hot battery cable (starter switch or solenoid). A fusible link is a piece of copper wire with hi temp insulation four gauges smaller (4 numbers larger) than the circuit wire it is supposed to protect. Use a #14 fusible link to protect #10 circuit wire All the big 3 use them, most good auto parts houses will have them.
