Re: cub lo-boy
Posted by screwstick on May 12, 2009 at 18:17:14 from (75.89.26.231):
In Reply to: cub lo-boy posted by Nicholaus Sowder on May 12, 2009 at 08:29:06:
Jred said: (quoted from post at 18:02:04 05/12/09) it can also be the main jet in the carb, there should be a seal below it since it sits below the fuel level. if the seal is not there or its bad it can poar out the intake.
A leaking seal on the jet will not cause fuel to spill out the intake. More than likely you have trash in your tank that is not allowing the needle to seat. Flush the entire fuel system.
