Re: Hit and miss
Posted by nosih on May 12, 2009 at 22:46:29 from (71.82.219.37):
In Reply to: Hit and miss posted by jake70d on May 12, 2009 at 20:34:05:
more than likely you just need to replace the packing, pump check balls, and the pump spring and the pump will work as good as new. 99% of the time that is all that is needed. Check with Starbolt Engine Supplies, I have added a link. I have had no problems with their parts on the IH and Hercules engines I have worked on, but have had problems with another suppliers parts not fitting.
