Re: H no spark
Posted by El Toro on May 13, 2009 at 04:12:14 from (205.188.116.73):
In Reply to: H no spark posted by jake70d on May 12, 2009 at 19:17:02:
Clean the points with some 320 wet or dry until shiny. If they're pitted replace them. If its a distributor you need to check for battery voltage to the coil. With the points open you should have battery voltage on both small terminals. Use a volt meter or test lite. A magneto does not require battery voltage since they can produce its own fire when the magnets pass by the coil, but they have points too and they need cleaning with 320 wet or dry. Check the point gap should be .013" on a mag and .020" on a distributor. Hal
