Re: Lo-Boy needs choke to run
Posted by Andy Martin on May 13, 2009 at 14:45:19 from (199.197.2.142):
In Reply to: Lo-Boy needs choke to run posted by Jred on May 13, 2009 at 11:45:32:
The most common reason for this is a leaking manifold. You can spray a little starting fluid or propane around the manifold and see if the engine speeds up. There can be a hazard in this if you spray too much and it catches fire. If you are unsure of the safety, try to tighten the manifold bolts, and if that does not help pull the manifold and check the gasket. This all assuming the gasket makes a good fit betweent eh carburetor and the manifold.
