Re: Farmall 100 Fast hitch lift capacity?
Posted by Hugh MacKay on May 13, 2009 at 15:30:52 from (209.226.106.37):
In Reply to: Farmall 100 Fast hitch lift capacity? posted by chad from michigan on May 13, 2009 at 10:56:21:
Chad: If I were going to use that mower, I'd build a 3 point kit for the 100. The 100 fast hitch should lift 600 lbs. providing the weight is close enough to tractor. The other item you must consider is route of PTO shaft. PTO shafts are not 100% user friendly with one point fast hitch.
If you wish send me an e mail and I'll show you how to built a 3 point kit that can be changed from 1 point to 3 point, or vice versa, in less than 5 min. and without wrenches. The 3 point will lift close to 40% more than 1 point. You will build this hitch for less than $400.00, using professional fabrication and new 3 point hitch replacement parts.
