Re: SuperA front axle disassembly
Posted by Hugh MacKay on May 13, 2009 at 15:44:08 from (209.226.106.37):
In Reply to: SuperA front axle disassembly posted by Adrian Billheimer on May 13, 2009 at 08:45:18:
Adrain: First remove the axle from the tractor. Then try and remove the other telescoping end. If you can find someone with a forge, it will make the job easier. Forge will be far more efficient.
I have seen these center tubes crimson from heat before it let go. If you try applying that kind of heat with axle on the tractor, you will very likely burn the tractor. I've had several of these tubes that hot, all are still going and my first attempt has 25 years on it now with center mount cultivators in summer and front snow blade in winter.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
