Re: PTO belt pulley belts - sources - repairs- lengths- h...
Posted by Kevin Wieber on May 13, 2009 at 15:57:05 from (74.60.81.9):
In Reply to: Re: PTO belt pulley belts - sources - repairs- lengths- h... posted by Dan G on May 12, 2009 at 09:40:35:
Most buzz saws I've used/saw have a belt tensioner or weighted pully to keep it tight.
If you have no tensioner I would make the belt tight so it can not be slid on easly. You may have to roll the pulleys a little to get the belt on. Most drive pulleys have a adjuster, probley a bolt in a sloted hole. You may need to use belt dressing, I use weatherstipping glue. Just a few stips the short way will do.
Good luck
Kevin
