Re: 1947 H, What should I do?
Posted by farmalldanzil on May 13, 2009 at 17:40:30 from (72.215.0.62):
In Reply to: 1947 H, What should I do? posted by Farmall Ed on May 13, 2009 at 06:43:10:
You might check the back hubs too see if one is loose. the wheel only has to move a small amount to do a lot of clicking on the axle.
thanks Dan .R.
