Posted by El Toro on May 13, 2009 at 18:07:57 from (64.12.116.73):
In Reply to: rod journal specs posted by 1941H on May 13, 2009 at 14:25:38:
You had better get the main journals measured too since they may be worn. You should have that engine block dipped and cleaned and all the oil passages blown out with air. Have new cam bearings intalled so you will have good oil pressure. You may as well install a new sleeve kit with new pistons. Hal
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
