Farmall M Power Steering
Posted by CWH on May 13, 2009 at 22:26:53 from (67.238.141.46):
A friend of mine has a Farmall "M" that has develpoed a power steering leak. The steering is a Char Lynn unit and the pump is leaking around the shaft behing the drive pulley. I haven't disassembled the pump yet but the best I can determine is the seal measures .75 inch X 1.250 inch. My question to you guys is this: does the seal remove and reinstall with the pump in one piece or with the pump disassembled? If I have to dissassemble the pump am I going to run into any unforseen problems or is this pump a straight forward gear type hydraulic pump? Thanks.
