Re: Super A rear wheel seal
Posted by gene bender on May 14, 2009 at 03:51:23 from (67.55.227.59):
In Reply to: Super A rear wheel seal posted by Jeff Sharp on May 14, 2009 at 03:26:53:
The inner seal on the axle is covered with a square shaped plate that has a gasket. The diff shaft does have two seals on the shaft and the housing needs to be removed to replaced. So where is the leak on the axle or the diff shaft.
