It s the clutch needing replaced or there s oil on the clutch from a leaking rear seal in the engine or front trans seal . Take inspection plate off the bottom and look for oil , had it happen to me . If clean and dry try adjusting the clutch to specs. It s not a bad tractor to split if seals or clutch is needed .
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
