Re: Re: Stuck Valve
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by David Saville on April 10, 2000 at 20:59:15 from (142.165.110.15):
In Reply to: Re: Stuck Valve posted by ltf in nc on April 10, 2000 at 13:29:23:
Unfortunatly this plan may not work on this engine. The tappets can seize in the guides and the guides bear on the head so the whole works holds tight untill the head is off, then the cam can push guide and all out of the block. If it is just the valve stuck you can put some soft rope in the spark plug hole and fill the cylender, then turn the engine slowly so the rope pushes the valve up. Repeat a few times untill it gets loose.
Post A Followup
: Re: Re: Re: Stuck Valve
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
