Re: Cub pto linkage problem
Posted by Jred on May 14, 2009 at 08:54:10 from (206.18.168.224):
In Reply to: Cub pto linkage problem posted by Farmall Ed on May 14, 2009 at 05:28:46:
Farmall Ed said: (quoted from post at 05:28:46 05/14/09) I have replaced two of the engagemnt levers,they cost a little over 50 bucks at the Ih dealer. There's not a lot of working room in this area,but you can move the tractor enough to get the ring gear flat and that will help. Ed
yea i had to do the same on mine, i picked up a good used one for cheap. you cant just weld in another pin, i tried that and it lasted all on an hour. they are heat treated.
it is possible it came out but if it popped out it was probubly worn out and needs replaced anyway.
