Posted by Bob M on May 14, 2009 at 12:42:25 from (151.190.254.108):
In Reply to: Farmall H Starter posted by chad504 on May 14, 2009 at 11:53:03:
It's a bendix issue indeed.
You might get lucky and find the pinion's simply jammed into the "home" position on the starter. Suggest removing the starter and see if the pinion is stuck. If it is work it loose on the bendix spiral. Then clean it and give the spiral a thin coat of light oil (hydraulic or tranny fluid works well).
Or you may also find the drive has broken (they do sometimes...) Any good starter shop can replace it for $50 or so. Just make sure it's for a Farmall H or M (these turn backward relative to most other bendix drive starters)
It's very unlikely the ring gear has broken. Ring gears usually fail slowly over several years - not all at once. You'll get random and intermittant grinding, starter non-engagement or jamming etc. These gradually increase in frequency until one day the starter simply won't drive the ring gear anymore.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
[More Ads]
