Re: Farmall M vs. WD 45 and John Deere A
Posted by RAW in IA on May 14, 2009 at 15:25:04 from (173.23.51.80):
In Reply to: Farmall M vs. WD 45 and John Deere A posted by Tom 43 on May 14, 2009 at 14:56:44:
A good M will run all over an A, but I think a WD 45 will give an M a run for its money, if not out pull it. I haven't been around a Allis that much, just know what I have been told. I do know athat around home an M will pull a 3-16 plow with no problem, but and A would have a hek of a time with it, unles someone had "worked" on the tractor for more power.
