Posted by Chris NW Ind on May 14, 2009 at 16:10:50 from (64.136.26.226):
I'll say right off that I haven't the means to check the flow, maybe the pressure. Anyhoo, I have this 806, power steering is kind of weak. Noticed the other day that if I was holding the brakes and I turned the wheel, the pedals would drop. Quit steering and the pedals would spring back. Brakes never slipped and I was backing up a hill. Also noticed the TA shifting from lo to high on its own a couple of times when moving from a dead stop--not constantly, though. Everything does work as advertised. The TA will shift crisply both ways in all gears, steering is tight, and the brakes easily lock up the wheels. Filter is new, and the fluid is clean and all the way up. Given the weak steering, I think I need a new MCV pump. What do you guys think?
One thing I need to do is check the oil tellight. It does light before starting the engine, but not when I push the clutch.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
