Re: McCormick Deering manifolds
Posted by old tired on May 14, 2009 at 17:33:30 from (64.91.21.125):
In Reply to: Re: McCormick Deering manifolds posted by James Williams on May 12, 2009 at 18:47:09:
Don't know if this will help but on 15-30 and 22-36 they came out the left side curtation from factory. Heisler made a mainfold that came out thru the hood I think it had a three bolt side mount carb. The factory had a two bolt carb. They made a p 300 powder unit that had the stack out the hood with a zenith updraft carb that was the same engine and verible gov. that was the same engine as a 22-36.
